×We run our automated Selenium tests via pipeline. We run at least once a day. However we're pushing the limits of a single step definition, so we're looking at a multi-step pipeline to avoid maxing out the time allotment per step.
The problem is, there's no way to "ignore" the errors in a step (aside from parallel steps, which don't help in this case, as the total execution time is still the same). Unless there is? I'm hoping I'm missing something simple. Is there an easy approach to keeping the tracking of test outcomes without blocking following steps?
Also, I'd really rather not use after-script to trigger a pipe or pipeline for this, because having a unified build log is important to the team that deals with test failures and releases.
Figured it out. A simple "[command] 2> /dev/null || true" appears to work.
