Images and Icons not loading when deploying web app from Pipeline
Abdul Haseeb
September 19, 2022
I'm deploying Flutter web apps from bitbucket pipeline with atlassian/firebase-deploy pipe. I'm getting broken images/icons when deploying from pipeline. But when I deploy from my Macbook using the same commands, my images are not broken. Please find the screenshots below.
bitbucket-pipelines.yml
1) Deployed from Macbook. 2) Deployed from pipeline
Screenshot 2022-09-20 at 10.56.42 AM.png Screenshot 2022-09-20 at 10.56.12 AM.png
Patrik S
September 22, 2022
Hello @Abdul Haseeb ,
In order to investigate further, I would like to ask a few questions :
  • What is the path where these images/assets are stored ? Are they stored in your repository directly or do you move them to the build/web/* artifact you are generating in the build step?
  • After deploying through the pipeline, if you check the destination end for the folder where the images/assets should be, are they present in the destination?
  • What exact command did you execute locally to have a successful deployment?
  • Could you try executing the same commands in a local docker container, following the instruction in Debug pipelines locally with docker ? This will simulate the environment of bitbucket pipelines. When testing locally, make sure to reset to the same exact commit as your failing pipeline is using :
    git reset --hard <commit ID>
Once you run the test locally, please share with us the log output. Make sure to sanitize any sensitive information from the logs.
Thank you, @Abdul Haseeb .
Patrik S
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
