I am trying to import a raw text file from a repo I have in bitbucket into power bi, but I get a file note found. Once I import this file, I want to evaluate the query ( I know how to do this) but I can't get access to the text file.
Can anyone tell me what syntax I need?
let
// Define the URL of the API endpoint
url = "https://bitbucket.org/broadspectrum/bustthetape/raw/7f104785464107f192272d47c30cf2766c57ea13/70061.txt",
// Set up the HTTP headers to include the Bearer token
headers = [
#"Authorization"="Authorization: Bearer Token"
// Get HTML content from the API
Source = Text.FromBinary(Web.Contents(url, [Headers=headers])),
// Example of parsing HTML content:
// This is a simplistic example where we look for a specific tag or pattern.
// This will need to be adjusted based on the actual HTML structure you're dealing with.
startIndex = Text.PositionOf(Source, "<tag>"),
endIndex = Text.PositionOf(Source, "</tag>"),
extractedValue = Text.Middle(Source, startIndex, endIndex - startIndex + 5) // Adjust length based on tags
// More complex parsing might be needed based on the HTML structure
// You might also need to split the text, extract parts using Text.BetweenDelimiters, etc.
in
extractedValue
G'day, @Luke D'Anastasi
Welcome to the community!
I believe you can't use the direct URL raw files if you are making an API request. You should use the following example:
https://api.bitbucket.org/2.0/repositories/<Workspace>/<Repo>/src/<commit>/<filepath>
Do note that you are required to log in with username app_password to authenticate.
Syahrul
Thanks Syahrul, can't I add an api token to the address to authenticate?
How would the syntax look like?
I literally just want to import the code I have in the text file, so I can then evaluate those instructions in Power Query.
Using a the RAW URL with Git works, but bitbucket I get a 404.
Hey @Luke D'Anastasi
I'm not an expert on Power Query, so I can't offer much help in that area. However, I can provide you with an example of how to obtain files using Curl:
curl -X GET -u <username>:<app_password> https://api.bitbucket.org/2.0/repositories/<Workspace>/<Repo>/src/<commit>/<filepath> --output file.csv
If you wish to use Token, please check our documentation on how to generate tokens and use them at:
https://developer.atlassian.com/cloud/bitbucket/rest/intro/#repository-access-tokens
For example, using a Repository access token:
https://support.atlassian.com/bitbucket-cloud/docs/using-access-tokens/
Syahrul
Power BI cannot deploy cURL commands.
Is there way I can do this via the REST API?
Noted. If that's the case I suggest asking this type of question directly on our community developer page at:
https://community.developer.atlassian.com/c/bitbucket-development/12
Syahrul
