×Hello,
We are AI chatbot provider company, and our client is using leon for flight scheduling, crew management, and operations. and they are willing to use the chatbot for transactions such as retrieving data from leon backend to show information to the end user, or to push information from the chatbot into leon backend "schedule flight for example". The question is, do you provide Restful APIs for such integration that can be used to fetch and push data back and forth the chatbot platform & leon backend for a seamless integration that will retrieve info to be provided to the chatbot's end users, and do transactions?
If yes, do you have any restrictions or limitations? Noting that the logic for fetching the data from the API endpoint will be written through Node JS scripts
Asma Thaher
Chatbot Architect at arabot
Hello @Asma Thaher and welcome to Atlassian Community!
This is a Bitbucket Cloud community, so I'm afraid we have limited knowledge of what APIs are offered by Leon AI.
After a quick research, I found the following API documentation on the Leon website which might be of help :
If you need further assistance on the capabilities of that API or if you have more questions about the Leon AI, I would suggest reaching out directly to their support and/or forum.
However, if you have a question specific to Bitbucket Cloud, feel free to reach out :)
Thank you, @Asma Thaher !
Patrik S
