Is it possible to use the aws-cloudformation-deploy pipeline to delete a stack
TimCoatesNHS
September 12, 2022
It's great to see the aws-cloudformation-deploy pipeline available, it makes it really easy to create a cloudformation stack from a pipeline.
It would be helpful to have a parameter which can be used to trigger a custom pipeline to delete an existing stack, to allow pipelines to clean up after themselves.
Could this be added as an optional parameter for example?
- pipe: atlassian/aws-cloudformation-deploy:0.13.0
  variables:
  # AWS_ACCESS_KEY_ID
  # AWS_SECRET_ACCESS_KEY
  # AWS_DEFAULT_REGION
  # STACK_NAME
  # TEMPLATE
  ACTION: DELETE # Defaults to create-stack, but this can be used to override
Igor Stoyanov
September 16, 2022
@TimCoatesNHS  hi. Thanks for your question.
Unfortunately, we will not implement stack deletion, but if you need this, you can check implementation  which you could use in your pipeline.
Regards, Igor
