Is it safe to include bitbucket-pipelines.yml on project level when compiling APK for release?
Bitwise DEVS
This is the sample project
Mark C
September 22, 2021
Hi @Bitwise DEVS
Thanks for reaching out to the community.
It should be safe to include your YAML file while compiling your project as long as you're not using any sensitive information in your YAML file (e.g. passwords, usernames, host/IP addresses etc.).
In case you have that sensitive information in your YAML file, make sure you're using Bitbucket Cloud environment variables as secured to hide them.
Hope it helps and let me know if you have further questions.
Mark C
Bitwise DEVS
Yes, currently using environment variable for such cases. Thanks
Like • Mark C likes this
