×image: python:3.5.1
pipelines:
custom:
default:
- step:
caches:
- pip
script:
- pip install awscli
- aws ssm send-command --document-name "AWS-RunRemoteScript" --instance-ids "i-xxxxx" --parameters '{"sourceType":["S3"],"sourceInfo":["{\"path\": \"https://s3.us-east-2.amazonaws.com/my-bucket-name/test.ps1\"}"],"executionTimeout":["3600"]}' --timeout-seconds 600 --region us-east-2
I have created a bitbucket-pipelines.yml file to test a powershell script that can run on remote AWS instance. When i try running it, i get the following error message for the last line:
"The 'script' section in your bitbucket-pipelines.yml file must be a list of strings".
I checked the syntax with other online YAML validators and it shows fine. Not sure why BitBucket is having issue. Any pointers?
Got the answer from SO.
Issue was with space before the \"https... string. Removing it fixed the issue
"sourceInfo":["{\"path\":\"https://s3.us-east-2.amazonaws.com/my-bucket-name/test.ps1\"}"]
