Issue with source in pipeline cloud storage
Md Parvez Alam December 13, 2020
I have below pipeline
image: node:10.15.3
pipelines:
  default:
      - step:
          caches:
            - node
          script:
            - rm -rf package-lock.json
            - rm -rf node_modules
            - npm install
      - step:
          script:
            - npm install --production
          artifacts:
            - build/**
      - step:
          script:
          - pipe: atlassian/google-cloud-storage-deploy:0.4.5
            variables:
              KEY_FILE: $KEY_FILE
              PROJECT: $PROJECT
              BUCKET: 'bucketname'
              SOURCE: 'build'
              CACHE_CONTROL: 'max-age=30'
              ACL: 'public-read'
The expected behavior is to deploy everything inside the build folder, but it uploads the build folder itself so in my storage, there is a build folder then everything inside this...
I have tried
'build/**' it picks only files and ignore directories
'buiid/' it behave same as 'build' picks build directory along with everything inside it directories and folders
'build/*' it picks only files and ignore directories
How can I everything inside build folder , files and diectories..
Md Parvez Alam December 14, 2020
I found the issue it's inside pipeline, I have written gsutil command to copy the folder recursively, and problem resolved
