Jest not found while running a pipeline
Krishna Kumar Singhal September 22, 2022
While trying to run a test automation suite in pipeline getting error, but the same command works locally:
script : "test-sanity": "jest webservices/specs/sanity/**/*.test.ts --maxWorkers=3 --forceExit",
+ umask 000
+ GIT_LFS_SKIP_SMUDGE=1 retry 6 git clone --branch="main" --depth 50 https://x-token-auth:$REPOSITORY_OAUTH_ACCESS_TOKEN@bitbucket.org/$BITBUCKET_REPO_FULL_NAME.git $BUILD_DIR
Cloning into '/opt/atlassian/pipelines/agent/build'...
+ git reset --hard 23070c5744edc443f3313c3b06698d526f53e002
HEAD is now at 23070c5 https://bitbucket.org/krishnatest1/nc-test-automation/src/23070c5744edc443f3313c3b06698d526f53e002/bitbucket-pipelines.yml edited online with Bitbucket
+ git config user.name bitbucket-pipelines
+ git config user.email commits-noreply@bitbucket.org
+ git config push.default current
+ git config http.${BITBUCKET_GIT_HTTP_ORIGIN}.proxy http://localhost:29418/
+ git remote set-url origin http://bitbucket.org/$BITBUCKET_REPO_FULL_NAME
+ git reflog expire --expire=all --all
+ echo ".bitbucket/pipelines/generated" >> .git/info/exclude
+ chmod 777 $BUILD_DIR
Images used:
build : docker.io/library/node@sha256:a5d9200d3b8c17f0f3d7717034a9c215015b7aae70cb2a9d5e5dae7ff8aa6ca8
+ npm test
> nc-testing@1.0.0 test
> jest webservices/specs/sanity/**/*.test.ts --group=$GROUP --maxWorkers=2 --forceExit
/tmp/test-bc16b754.sh: 1: /tmp/test-bc16b754.sh: jest: not found
Searching for test report files in directories named [test-results, failsafe-reports, test-reports, TestResults, surefire-reports] down to a depth of 4
Finished scanning for test reports. Found 0 test report files.
Merged test suites, total number tests is 0, with 0 failures and 0 errors.
Issue resolved, need to pass the node_modules as artifacts
Jun Tabudlong
July 9, 2024
Hi @Krishna Kumar Singhal how did you point your artifacts option to node_modules? tia!
