×Hi, I've setup an automation sending a message to microsoft teams when an issue is commented. I followed the instructions in the action details (add connector in teams channel, copy webhook url, paste it into automation action).
When the rule is triggered I get an error:
Error communicating with the API400 - Webhook Bad Request - null or empty eventType
On the other side, if I set up the same webhook communication via Jira system settings -> webhook -> create new webhook and send messages from there, it works.
what am i doing wrong?
Try using a different Connector on MS Teams side called Incoming Webhook.
Hi Martin,
Thanks for your suggestion. I had the same error of Webhook Bad Request - null or empty eventType.
I tried your suggestion and it worked perfectly.
regards,
zaldy
Same problem and same fix worked. Thanks for asking @zaldy parian and thanks for answering @Martin Ceska
What should I do if I cannot see this webhook? Does it need to be enabled from somewhere else?
I've tried to follow: Create an Incoming Webhook - Teams | Microsoft Docs.
Thanks Guys
Mine worked better with the Incoming Webhook.
No errors :)
Most likely this is caused by trying to send the request to a JIRA Cloud connector hook in Teams instead of a (generic) Incoming Webhook connector hook.
Edit: Seems like this was already answered above.
thanks for your reply, worked on my end. Do you know the technical difference between both solutions?
The issue is that JIRA is sending a different JSON response when doing it from a transition , vs those checkboxes.
I hooked up the webhook to a https://webhook.site/ and when I pushed the response along to to MS teams - I got "Webhook Bad Request - null or empty eventType" - which it doesn't have
Only the ones triggered from "created, updated" have this metadata
Has this been investigated further yet as i'm attempted to trigger a webhook into a Microsoft Teams Channel based off a simple JQL query.
I tried to use Incoming Webhook but to no avail, any suggestions?
[Not the answer] I have the same question.
I want to use the automation action and when I use in conjunction with creating new webhook in the way Oliver describes, it does send a message to Teams. However, all the formatting and message content that I created in automation is not used.
