Maven cache sometimes not working
Mark Gortzak August 9, 2023 edited
I have a pipeline that does a Maven install, and then a SonarCloud analysis using Maven. I have a m2 repository cache configured in the pipeline. I see the cache being used during the Maven install, but not in the Maven SonarCloud analysis. This is constant after three builds.
I have a private Nexus repository where dependencies are downloaded.
The cache is configured as follows:
definitions:
  caches:
    custom-maven:
      key:
        files:
          - pom.xml
      path: /usr/share/maven/ref/repository
The Maven install step is as follows:
- step: &build-test
    name: Build & test
    caches:
      - custom-maven
    script:
      - mvn -B -T2C install -s ./settings.xml
    artifacts:
      - target/*.jar*
The SonarCloud analysis:
- step: &sonarcloud
    name: Static code analysis using SonarCloud
    image:
      name: [some private image]
      username: $DOCKER_USERNAME
      password: $DOCKER_PASSWORD
    caches:
      - custom-maven
      - custom-sonar
    script:
      - mvn -B -T2C verify sonar:sonar -s ./settings.xml
The (I think) relevant bit from settings.xml:
<localRepository>/usr/share/maven/ref/repository</localRepository>
The logs of the Maven install:
+ mvn -B -T2C install -s ./settings.xml
[INFO] Scanning for projects...
[INFO]
[INFO] Using the MultiThreadedBuilder implementation with a thread count of 8
[INFO]
[INFO] ----------------------< package:artifact >----------------------
[INFO] Building artifact 1.2.3.BUILD-SNAPSHOT
[INFO] --------------------------------[ jar ]---------------------------------
The logs of the SonarCloud analysis:
+ mvn -B -T2C verify sonar:sonar -s ./settings.xml
many more downloads
[INFO]
[INFO]
The cache is available when I look in the Bitbucket UI:
What I want is for the caching to work during the SonarCloud analysis as well. What is going on here? What can I do to fix this?
Mark Gortzak August 15, 2023
I talked with support, the cache is being used. The build time is faster. Maven seems to sometimes/always download certain dependencies. This might be a problem with our Maven configuration. So it has nothing to do with Bitbucket.
Syahrul
August 10, 2023
G'day, @Mark Gortzak
We require to review your pipeline build to investigate the issue further. Since an in-depth investigation is required, I have proceeded to raise a support ticket on your behalf.
Please find your ticket at our support portal:
https://support.atlassian.com/requests/
Syahrul
atlassian, state of devex 2025, developer experience, devex report, developer productivity, ai in software development, engineering challenges, team collaboration, internal developer platform, time management, developer survey, space framework
Atlassian State of Developer Experience Report 2025
AI is reshaping the dev experience, with faster builds but adding more friction. See what 3,500 developers and managers say about productivity, tools, and team alignment in Atlassian’s State of Developer Experience report 2025.
Explore the report
