My repositories are missing
TuahZh March 28, 2024
I logged in yesterday and found all my repositories are missing. I have tried the steps suggested in some posts here like searching all the workspaces. But I cannot find my private repositories.
3 votes
Ben
March 28, 2024
Hi @TuahZh
I would suggest executing the following command to view a list of your remote connections and taking note of the workspaceID that appears before the repository slug in the URL:
git remote -vvv
Once logged in, view all of your workspaces and check their Workspace Settings > General settings to see if these match the workspaceID's that you are seeing in your remote list - this should help you locate the repositories.
If you can't find them I'd suggest logging into Bitbucket using any of your email addresses that you have access to (if prompted for signup, do not create a new workspace). To help you find email addresses that may have been used with Bitbucket you can use the following command:
git config --list
If you encounter issues, please let me know.
Cheers!
- Ben (Bitbucket Cloud Support)
Thank you very much. I can see them by changing my workspace name to TuahZh that is the name of the workspaceID.
Like Ste Wright likes this
Ben
March 28, 2024
Awesome! Happy to help! :D
Ste Wright
Hi @TuahZh
So we don't suggest the same things, what have you tried so far?
Ste
I have successfully got back my repositories by changing the workspace's name to the same as the ID name. Thank you!
