Need help with maven dependency cache
bayarkhuu
February 14, 2024
Im trying to cache my maven dependencies.
after step one succeeded (log):
Cache "maven: /root/.m2/repository": Skipping upload for empty cache
My configs:
#Dockerfile
# Stage 1: Build Stage
FROM maven:3.8.2-openjdk-17-slim AS build
WORKDIR /app
# Copy the pom.xml file
COPY pom.xml .
# Create the .m2 directory and copy settings.xml
RUN mkdir -p /root/.m2
COPY settings.xml /root/.m2/
# Download dependencies
RUN mvn dependency:go-offline
# Copy the rest of the application
COPY . .
# Build the application
RUN mvn clean install -DskipTests
# Stage 2: Run Stage
FROM amazoncorretto:17.0.9-alpine3.18
WORKDIR /app
# Copy only the necessary files from the build stage
COPY --from=build /app/target/admin-api.jar admin-api.jar
ENTRYPOINT ["java", "-jar", "admin-api.jar"]
# bitbucket-pipelines.yml
image: alpine:latest
definitions:
caches:
services:
docker:
image: docker:dind
memory: 3072
pipelines:
custom:
office-server:
- step:
fail-fast: true
user: root
runs-on:
- self.hosted
- linux
- office
name: Docker build & Push
services:
- docker
caches:
- maven
- docker
script:
- echo "$DOCKER_PASSWORD" | docker login -u "$DOCKER_USERNAME" --password-stdin harbor.medsoft.care
- TAG=$(echo $BITBUCKET_COMMIT | head -c 8) # Use the first 8 characters of the commit hash as the tag
- echo $TAG
- DOCKER_BUILDKIT=1 docker build -t harbor.medsoft.care/medsoft8/admin-service:$TAG .
- docker push harbor.medsoft.care/medsoft8/admin-service:$TAG
- docker tag harbor.medsoft.care/medsoft8/admin-service:$TAG harbor.medsoft.care/medsoft8/admin-service:latest
- docker push harbor.medsoft.care/medsoft8/admin-service:latest
- step:
fail-fast: true
user: root
runs-on:
- self.hosted
- linux
- office
name: Deploy to Kubernetes
script:
- pipe: atlassian/kubectl-run:3.10.0
variables:
KUBE_CONFIG: $KUBE_CONFIG
KUBECTL_COMMAND: set image deployment/admin-service admin-service=harbor.medsoft.care/medsoft8/admin-service:$TAG
Theodora Boudale
February 16, 2024
Hi @bayarkhuu,
Caches can be used for directories in the build container. Your build doesn't download the maven dependencies in the build container, but in the Docker image that you are building. Therefore, there is nothing in the directory /root/.m2/repository of the build container to cache.
You can use a Docker cache, but the predefined docker cache used for caching the layers produced during Docker Build operations does not cache layers produced when using BuildKit.
If Docker BuildKit is enabled and the build layers need to be cached, we recommend using the Docker Build --cache-from option. This allows one or more tagged images stored in an external image registry to be used as a cache source. You can find more details here:
Theodora
atlassian, state of devex 2025, developer experience, devex report, developer productivity, ai in software development, engineering challenges, team collaboration, internal developer platform, time management, developer survey, space framework
Atlassian State of Developer Experience Report 2025
AI is reshaping the dev experience, with faster builds but adding more friction. See what 3,500 developers and managers say about productivity, tools, and team alignment in Atlassian’s State of Developer Experience report 2025.
Explore the report
