Here's what I came up with - PLEASE help me verify!
1) IPv4 inbound for bitbucket.org, api.bitbucket.org, and altssh.bitbucket.org
104.192.136.0/21
185.166.140.0/22
13.200.41.128/25
2) IPv6 inbound for bitbucket.org, api.bitbucket.org, and altssh.bitbucket.org
2401:1d80:320c:3::/64
2401:1d80:320c:4::/64
2401:1d80:320c:5::/64
2401:1d80:3208::/64
2401:1d80:3208:1::/64
2401:1d80:3208:2::/64
2401:1d80:3210::/64
2401:1d80:3210:1::/64
2401:1d80:3210:2::/64
2401:1d80:321c::/64
2401:1d80:321c:1::/64
2401:1d80:321c:2::/64
2401:1d80:322c:2::/64
2401:1d80:322c:3::/64
2401:1d80:322c:5::/64
2401:1d80:3218:1::/64
2401:1d80:3218:3::/64
2401:1d80:3218:4::/64
2401:1d80:3220::/64
2401:1d80:3220:1::/64
2401:1d80:3224::/64
2401:1d80:3224:1::/64
2401:1d80:3224:2::/64
3) Valid IP addresses for Bitbucket Pipelines build environments:
NOTE: Service: EC2, region: eu-central-1
35.50.192.0/24
18.96.32.0/19
3.5.136.0/22
18.192.0.0/15
136.18.142.0/23
64.252.89.0/24
63.176.0.0/14
99.77.136.0/24
5.60.32.0/22
15.145.2.0/23
63.180.0.0/14
52.58.0.0/15
15.220.48.0/21
18.184.0.0/15
52.57.0.0/16
35.96.12.0/24
54.93.0.0/16
3.124.0.0/14
35.96.96.0/20
15.220.64.0/20
3.33.35.0/24
52.95.255.128/28
83.119.128.0/18
15.220.152.0/21
18.156.0.0/14
15.220.144.0/23
35.96.48.0/20
64.252.87.0/24
15.145.0.0/23
99.77.158.0/24
35.50.194.0/24
3.64.0.0/12
151.148.35.0/24
15.145.12.0/22
99.77.247.0/24
64.252.88.0/24
35.50.193.0/24
52.29.0.0/16
99.151.188.0/23
15.193.4.0/24
99.150.16.0/21
3.120.0.0/14
18.198.0.0/15
52.94.248.112/28
35.96.5.0/24
35.156.0.0/14
5.60.24.0/22
15.145.16.0/22
15.145.4.0/23
18.153.0.0/16
173.83.196.0/23
64.252.86.0/24
18.196.0.0/15
52.95.248.0/24
52.94.146.0/24
18.89.0.0/18
18.194.0.0/15
52.46.184.0/22
35.71.105.0/24
52.28.0.0/16
15.145.8.0/22
3.5.134.0/23
15.177.68.0/23
Hi @Budggy Inc. and welcome to the community!
The IPs Bitbucket Cloud uses are listed on this page:
I assume you copy-pasted in your post the IPs from the page I shared?
The Valid IP addresses for Bitbucket Pipelines build environments are needed only if you run Pipelines builds on Atlassian's infrastructure and you want to connect to your own server during the Pipelines build. Is this what you are trying to do? If so, please keep in mind that the documentation of Bitbucket Pipelines Cloud IP addresses is divided into two sections:
Section 1: Valid IP addresses for Bitbucket Pipelines build environments
This section applies to 1x/2x step sizes (or 4x/8x steps that have not been explicitly flagged to use atlassian-ip-ranges). An exhaustive list of IP addresses from which the traffic may originate on AWS can be obtained by using the following endpoint. You should filter records where the service equals EC2 or S3, and focus on the us-east-1 and us-west-2 regions. However, we do not recommend using these IP ranges as a security control due to their broad nature.
Section 2: Atlassian IP Ranges
This section pertains to steps specifically configured to use Atlassian IP ranges. These are applicable only to 4x and 8x size steps that have the atlassian-ip-ranges: true
flag enabled. The step sizes 4x and 8x are only available for builds running under a paid Bitbucket Cloud plan (Standard or Premium).
The documentation for the configuration needed in order for a Pipelines step to use this more limited set of IPs is documented here:
https://support.atlassian.com/bitbucket-cloud/docs/step-options/#Runtime
This configuration improves security by restricting the IP addresses utilized by Pipelines builds to the Atlassian IP ranges.
I hope this helps. If you have any questions, please feel free to let me know and also share some more details on what you are trying to do (e.g. if you want to connect to your server from Bitbucket Pipelines or if want to do something different).
Theodora
Hi @Theodora Boudale ,
Thank you so much for your elaborate response, wishing you a happy new year.
What we are trying to do is this: Use OpenID Connect to run BB Pipelines on our AWS EC2 instance. The setup followed the recommended procedure, but I can't seem to get the Fetch Fingerprint to work, it is always stuck at the SSH connection stage. We tried to manually embed it using the private IP of the instance - same issue. I just needed to know which IP BB tried to access the instance, so I verify if my setup was correct for the SSH inbound rules.
Yes @ "you run Pipelines builds on Atlassian's infrastructure and you want to connect to your own server during the Pipelines build. Is this what you are trying to do?" - and no, will not use the Atlassian IP Ranges.
Please let me know if this is clear enough, thank you so much!
Happy new year to you too, @Budggy Inc.!
Thank you for the additional information!
The IP addresses for bitbucket.org, api.bitbucket.org, and altssh.bitbucket.org in your post seem to be the ones from our documentation.
However, the IP ranges for Pipelines environments in your post have Service: EC2, region: eu-central-1.
If you are not planning to use Atlassian IP ranges, then from the following endpoint you need to get the IP ranges where service equals EC2 or S3, and out of these, filter further on the us-east-1 and us-west-2 regions (not the eu-central-1 region).
Please also keep in mind that when you try to fetch the fingerprint, you need to provide the public IP address or domain name of your server. Bitbucket will try to connect to your server over the internet in order to fetch the fingerprint (and also during the build), and private IP addresses can only be used in a local network.
Please feel free to let me know how it goes.
Theodora
I am having similar issue.
We have added the Atlassian IP Address to our security group because we plan to use 4X build. But When I try to get the Known Host, I says there is a SSH error. Does the Known Host fetch not run through one of those IP addresses?
I too am having a similar issue even after we whitelisted Atlassian IPs
My network admin asked "What specific bitbucket service are you using. Is it pipelines?" I answered yes and then sent me the information below regarding "OIDC"
Does this make sense? I'm not a network guy - Is this the direction I need to go?
The servers that execute all steps on Atlassian Cloud Infrastructure, are hosted on Amazon Web Services (AWS).
An exhaustive list of IP addresses that the traffic may come from on AWS can be found by using the following endpoint, filtering to records where the service equals EC2 or S3, and using the us-east-1 and us-west-2 regions. We do not recommend using these IP ranges as a security control.
If you prefer to use a more limited or narrowed IP range, you should utilize the atlassian-ip-ranges that are available in the new larger instances (4x and above).
As a reminder, Atlassian does not recommend configuring IP-based firewalls as the only mechanism to protect access to your infrastructure. As an example In addition to IP-based firewall rules, you should also use a secure means of authentication for any services exposed to Bitbucket Pipelines (e.g., by using OIDC).
Ok, looks like we need to dig further and implement this: https://support.atlassian.com/bitbucket-cloud/docs/integrate-pipelines-with-resource-servers-using-oidc/
