Hello!
According to Your REST API documentation and the same question, I must be able to create a PR with REST API, but every time I'm getting 400 response.
I tried to make this request (also the same with Python):
curl -v https://api.bitbucket.org/2.0/repositories/<org_name>/<repo-name>/pull-requests \
-u my-username:my-password \
request POST \
header 'Content-Type: application/json' \
data '{
"title": "My Title",
"source": {
"branch": {
"name": "test_12345"}}}'
and I've received this error:
{"type": "error", "error": {"message": "Resource not found", "detail": "There is no API hosted at this URL.\n\nFor information about our API's, please refer to the documentation at: https://developer.atlassian.com/bitbucket/api/2/reference/"}}
Could I ask you please to help me with it?
What I'm doing wrong?
Hi @Vitalii Bendyna ,
you are using the wrong format :
Your https://api.bitbucket.org/2.0/repositories/<org_name>/<repo-name>/pull-requests
Correct https://api.bitbucket.org/2.0/repositories/my-workspace/my-repository/pullrequests
Hope this helps,
Fabio
Yep, thanks. Somehow it worked.
But with python requests library still I'm not able to do it... Never-mind, I used curl))
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
