Please find the configured pipeline below
Find Error below from the pipeline
npm notice
npm verb stack Error: This command requires you to be logged in to $NPM_REGISTRY
npm verb stack at Publish.exec (/usr/local/lib/node_modules/npm/lib/commands/publish.js:110:29)
npm verb stack at async module.exports (/usr/local/lib/node_modules/npm/lib/cli-entry.js:61:5)
npm verb cwd /opt/atlassian/pipelines/agent/build
npm verb Linux 5.15.0-1044-aws
npm verb node v18.18.0
npm verb npm v9.8.1
npm ERR! code ENEEDAUTH
npm ERR! need auth This command requires you to be logged in to $NPM_REGISTRY
npm ERR! need auth You need to authorize this machine using `npm adduser`
npm verb exit 1
npm verb code 1
npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-10-17T08_46_19_082Z-debug-0.log
+ status=1
+ set -e
+ [[ 1 -eq 0 ]]
+ fail 'Failed to publish package "@apollo247/pharma-cart-sevice@1.0.0-alpha16".'
+ echo -e '\e[31m✖ Failed to publish package "@apollo247/pharma-cart-sevice@1.0.0-alpha16".\e[0m'
+ exit 1
Hi Pranshu and welcome to the community!
The README of the pipe's repo mentions the following:
By default, the pipe publishes to npmjs.com. You can publish to any other registry by adding a publishConfig.registry key in your package.json. See npm documentation for more details.
Are you publishing to a registry other than https://npmjs.com/? If so, have you configured the publishConfig.registry key in your package.json?
Theodora
Yes, I'm publishing to a registry other than npmjs and some had been configured in publishConfig.registry key
