×Occasionally a pipeline fails due to a failure to connect to the pluginAuthZPlugin.AuthZRes. Here is the docker error log:
time="2019-11-24T14:26:50.782904282Z" level=warning msg="Unable to connect to plugin: /run/docker/plugins/pipelines.sock/AuthZPlugin.AuthZRes: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZRes: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused, retrying in 1s"
time="2019-11-24T14:26:51.783581826Z" level=warning msg="Unable to connect to plugin: /run/docker/plugins/pipelines.sock/AuthZPlugin.AuthZRes: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZRes: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused, retrying in 2s"
time="2019-11-24T14:26:53.788686520Z" level=warning msg="Unable to connect to plugin: /run/docker/plugins/pipelines.sock/AuthZPlugin.AuthZRes: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZRes: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused, retrying in 4s"
time="2019-11-24T14:26:57.789059713Z" level=warning msg="Unable to connect to plugin: /run/docker/plugins/pipelines.sock/AuthZPlugin.AuthZRes: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZRes: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused, retrying in 8s"
time="2019-11-24T14:27:05.789590970Z" level=error msg="AuthZResponse for POST /v1.25/build?t=hdp_amphora_local_django&q=False&nocache=False&rm=True&forcerm=False&pull=False&dockerfile=.%2Fcompose%2Flocal%2Fdjango%2FDockerfile returned error: plugin pipelines failed with error: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZRes: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused"
time="2019-11-24T14:27:05.789656585Z" level=error msg="Handler for POST /v1.25/build returned error: plugin pipelines failed with error: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZRes: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused"
2019-11-24 14:27:05.789696 I | http: multiple response.WriteHeader calls
time="2019-11-24T14:27:05.796135397Z" level=warning msg="Unable to connect to plugin: /run/docker/plugins/pipelines.sock/AuthZPlugin.AuthZReq: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZReq: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused, retrying in 1s"
time="2019-11-24T14:27:06.797576578Z" level=warning msg="Unable to connect to plugin: /run/docker/plugins/pipelines.sock/AuthZPlugin.AuthZReq: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZReq: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused, retrying in 2s"
time="2019-11-24T14:27:08.797997268Z" level=warning msg="Unable to connect to plugin: /run/docker/plugins/pipelines.sock/AuthZPlugin.AuthZReq: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZReq: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused, retrying in 4s"
time="2019-11-24T14:27:12.798347438Z" level=warning msg="Unable to connect to plugin: /run/docker/plugins/pipelines.sock/AuthZPlugin.AuthZReq: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZReq: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused, retrying in 8s"
time="2019-11-24T14:27:20.798690871Z" level=error msg="AuthZRequest for GET /v1.25/containers/json?limit=-1&all=0&size=0&trunc_cmd=0&filters=%7B%22label%22%3A+%5B%22com.docker.compose.project%3Dbuild%22%2C+%22com.docker.compose.service%3Ddjango%22%2C+%22com.docker.compose.oneoff%3DFalse%22%5D%7D returned error: plugin pipelines failed with error: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZReq: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused"
time="2019-11-24T14:27:20.798740006Z" level=error msg="Handler for GET /v1.25/containers/json returned error: plugin pipelines failed with error: Post http://%2Frun%2Fdocker%2Fplugins%2Fpipelines.sock/AuthZPlugin.AuthZReq: dial unix /run/docker/plugins/pipelines.sock: connect: connection refused"
Googling did not help much. Anybody any ideas?
Are there any updates on this issue? It happens very occasionally with `docker tag` or `docker push` commands. Can I provide some more logs or something else to help?
I don't know what to do here, as it happens very randomly & sometimes we can't deploy for several hours. So for us it's a serious blocker at the moment.
we are having the same issue, fails randomly.
Same error with Bitbucket Pipelines Pipe: AWS ECR push image.
I don't know if it's a fix or if Atlassian fixed something, but since I added the following to my bitbucket-pipelines.yml file I did not get this error anymore:
definitions:
services:
docker:
memory: 2048
this fixed it for me as well
I have following values and got this error sometimes.
definitions:
services:
docker:
memory: 3072
same here. Would be great to have a fix, we're loosing plenty of times at each fail.
C'mon guys pls say something! We suppose to be a community, not just a wailing wall...
We are facing the same problem
Same. Can't push image
Seems to be still a problem....
Our tests are not that big that is should be a problem with 2048 memory.
This is really a waist of time, have to build 5-10 times until it get trough.
I have the same problem here
Almost one year without any answer... I also have the same problem here
Same error
Same error with sonarsource/sonarcloud-quality-gate:0.1.3
Same error.
Please fix as soon as posible.
Same
