Hello Team,
We are working on a proof of concept which to assess use of cloud bit bucket pipelines to deploy in our on premise machines.
The high level steps are :
a. Build .net, SSRS , SSIS (SQL Server) code
b. Deploy in onprem servers
While running through the documentations and trying to run some simple pipelines. I stumbled upon the following blockers :
1. Limited SSRS / SSIS build tool support :
I didn't find sufficient examples and documentation for SSRS or SSIS (Microsoft SQL Server) deployments. I also checked on the Atlassian market place to see if we have any supported products which can accomplish the build step of SSRS / SSIS projects but I didnt find any. I really appreciate your help in getting me to to Atlassian support for SSRS / SSIS build tools
2. Deploy / Push the code to on premise servers :
I went through the documentation page related to the ticket BSERV-9245 for using Bit Bucket for on premise but it appears that Snake CI has supported limited to Java, Node.js or Go
https://community.atlassian.com/t5/Bitbucket-questions/BitBucket-Pipelines-on-premise/qaq-p/605548
while configuring the pipeline i found the pipe "atlassian/sftp-deploy:0.5.7" I can use this to push the code to my server once I open the SFTP port. Would this plugin help resolve the issue of pushing compiled code into my onprem server ?
Did you ever find a solution for this. In a similar situation.
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
