PAYLOAD_FILE without MESSAGE does not work for slack_notify pipe
Steve Annett July 7, 2023
Hi
In the last example of https://bitbucket.org/atlassian/slack-notify/src/master/ it shows how to use a payload file
script:
  - envsubst < "payload.json.template" > "payload.json"
  - pipe: atlassian/slack-notify:2.0.1
    variables:
      WEBHOOK_URL: $WEBHOOK_URL
      PAYLOAD_FILE: payload.json
But when I try it, with slack-notify:2.0.1, I get
✖ Validation errors:
MESSAGE:
- required field
Oleksandr Kyrdan
July 7, 2023
Hi @Steve Annett
Thank you for your question!
We'll fix it in the future release.
Best regards,
Oleksandr Kyrdan
Steve Annett July 10, 2023
I can confirm having a blank message works as a workaround for now
script:
    variables:
MESSAGE: " "
