PHP Laravel Pipeline: No Artifacts Uploaded
nymendaros June 9, 2022
My artifacts is not uploaded after successful run of test pipeline. Here's the yml:
here's the result
what should the correct code for the artifact?
Theodora Boudale
June 13, 2022
Hi @nymendaros,
I see two issues with the yml file you posted:
1st. The two steps are parallel. Parallel steps can only use artifacts produced by previous steps, not by steps in the same parallel set.
If you want the second step to use an artifact generated by the first step, you will need to remove the parallel keyword.
2nd. I'm afraid that the file path in artifacts cannot render variable names. We have a bug report about this in our issue tracker:
As a workaround, you can determine as an artifact any file with .zip extension as follows:
artifacts:
- "*.zip"
In case you have multiple zip files in the clone directory and you want to avoid having all of them uploaded as artifacts, you can generate this specific zip in a separate folder inside the clone directory, e.g. named 'app', and then define as an artifact any zip file in that directory
artifacts:
- app/*.zip
Please feel free to let me know how it goes and if you need further assistance.
Theodora
nymendaros December 20, 2022
Sorry for late reply. Thank you for the assistance
This has been solved on the same month (June). We're able to fix the pipeline by removing the parallel directive for the 1st and 2nd step and among other things.
But the $BITBUCKET_BUILD_NUMBER is not incrementing.
Theodora Boudale
December 21, 2022
Hi @nymendaros,
Thank you for the update and you are very welcome! It's good to hear that the issue was solved.
Regarding $BITBUCKET_BUILD_NUMBER not incrementing, have you perhaps defined a deployment variable, repository variable, or workspace variable with the same name? These variables will override default ones with the same name.
If you add the command ls -lah below the zip command as follows, does the number in the name of the zip not correspond to the build number?
- zip -r example-$BITBUCKET_BUILD_NUMBER.zip .
- ls -lah
In case you are generating the zip in a directory inside the clone directory, provide the directory name in the ls -lah command.
Theodora
