PR management in Slack
Ayşegül Yavuz Gökçüoğlu
Hi everyone!
As Actioner team, every day, we’re working on Slack-first solutions to ease the day of a knowledge worker. We also publish them in the Actioner app directory. Recently we have focused on the PR management process, and since DevOps people are the majority of our team, we had to find a solution. 🧑🏽‍💻
PR management with the Bitbucket app allows developers to ➡️
  1. Collaborate on an open pull request in a temporary Slack channel, get informed about the updates, and approve or merge the PR without leaving Slack.
  2. Broadcast new commits to the main branch through a dedicated Slack channel for Bitbucket updates.
If you get overwhelmed due to switching between Bitbucket and Slack, you should definitely take a look at our use cases. Or get started with PR management with Bitbucket right away 😉
Note: Tools you can integrate with Slack are not limited to Bitbucket; you can integrate your entire tool stack and build workflows according to your needs. As Actioner team, we invite you to work magic in Slack 🪄.
We can’t wait for you to explore Actioner and give feedback!
