Permission denied for SSH on Pipelines
maximilianruediger
August 9, 2018
Hi there,
I followed this guideline to create a new SSH key for my repo:
https://confluence.atlassian.com/bitbucket/use-ssh-keys-in-bitbucket-pipelines-847452940.html
I created it in the repo settings (also added the server to the known hosts) and added the public key on the remote server.
Now, I want to access my remote server in a Bitbucket Pipeline via:
ssh -T user@XX.XX.XX.XX rm testfile
But I stuck on that:
Permission denied, please try again.
Permission denied (publickey,password).
Where is the fault that I cannot access my remote server to execute the command?
Thanks a lot
Philip Hodder
August 16, 2018
Hi Max,
Can you try do a quick check that the connection works:
$ ssh -qT user@downhost exit
$ echo $?
// Should be 0
Your user may not have permission to modify files, so it'll be good to remove that factor first. If you get a 0, then double check the permissions of the user you're SSH'ing as.
If not, you can also double check you have whitelisted the necessary Pipelines IP's.
Phil
Olusiji David
October 27, 2018 edited
Hi Philip,
Im having this same issue, i ran the commands you stated and i got a 0, but i still get the permission denied error. Please any suggestions what might be wrong?
Philip Hodder
October 28, 2018
@Olusiji David,
Can you try run this instead. I forgot there's an edge case with the way error codes work.
$ ssh -qT user@downhost exit; echo $?
Sebastian Erdt March 29, 2019
Hi Philip,
Where exactly is this command to be executed? In the bitbucket-pipelines.yml file or on the  remote computer? Do I have to customize user@downhost or leave it in the command?
$ echo $?
// Should be 0
When I run this on the remote computer I get a value of 255. What should I do afterwards?
Sorry for the many questions, but I am still a beginner in the field.
Sebastian
Like • SDA Media likes this
5 votes
Mark Drew
November 23, 2018
I struggled with this for a day and followed all the comments without it working.
The one thing that eventually worked for me was letting bitbucket create the private and public keys and using those instead of the ones I created myself.
I then added the public key (as it says ) to the server's `~/.ssh/authorized_keys` file (as a new line)
It all then worked.
panter122
September 4, 2019
Thank you, helped me a lot!
Like • Mark Drew likes this
ewertoncardoso
January 4, 2020
Thank you! Works for me!
William Odiomonafe
February 18, 2020
Also worked for me too
John Kabiu
July 21, 2020
Hello.. how do i let bitbucket create the ssh. i not that good with Atlassian products
Surya Van Lierde November 18, 2020
@John Kabiu
On the repository -> Repository Settings -> Scroll to Pipelines / SSH keys -> Generate
Like • ewertoncardoso likes this
Shashikumar January 11, 2021
Thank you!
Mohan G
June 9, 2021 edited
I was almost struggling for a couple of hours to transfer files through scp.. Finally, I could solve the issue based on Mark's response. Thanks.
Points to note:
1) I didn't remove my existing public key which I used to login
2) I generated one more key pair using the ssh key generator provided by bitbucket and appended that key to the authorized_keys under ~./ssh directory. So, now bitbucket pipelines will be using the keypair that was generated by using bitbucket cloud rather than the earlier key that I had provided.
3) Permissions I had set: 700 for .ssh dir and 600 for authorized_keys under .ssh directory
Daniel Bello
May 11, 2022
Hello team
I keep getting the same error, but with a GitHub repo, while running npm install https://shero.d.pr/l6fHt7
I have created the bitbucket keys but am not sure where to upload these on Github.
3 votes
wuppr
April 6, 2023 edited
This may be applicable to many individuals who are using newer operating system versions.
To determine whether this applies to you, it is recommended that you check your SSH logs. You can locate these logs at /var/log/auth.log (for Ubuntu) and search for the following message:
"userauth_pubkey: key type ssh-rsa not in PubkeyAcceptedAlgorithms [preauth]".
If you come across this log message, it is likely that you will need to upgrade your SSH key (used in the pipeline) to a newer and more stringent algorithm, such as ED25519. You can generate a new ED25519 key and add both the public and private keys to the Repo settings -> Pipelines -> SSH Keys. Finally, use the public key in the authorized_keys of your remote server.
I hope this information is helpful. I spent several hours searching for this problem and ultimately found it by examining the SSH logs.
 More info: https://confluence.atlassian.com/bitbucketserverkb/ssh-rsa-key-rejected-with-message-no-mutual-signature-algorithm-1026057701.html
Angelos Naoum July 19, 2023
Thank god! I was struggling for hours...this is the issue I had as well
mortenbak
January 12, 2024
Thank you! This was exactly what I needed!
miso
December 2, 2019
For me, the problem was at the target server. I needed to set `chmod 0775 ~/.ssh` so the server started accepting the SSH auth for the user.
jfranklin
August 27, 2021
user beware: this locked me out of my server
