Pipe "aws-ecr-push-image" using "ECR_PUBLIC=true" makes it mandatory to tag image differently
Nino Gresenz
July 15, 2024
Hello Bitbucket Team,
I was trying to push an image to AWS ECR public and used the aws-ecr-push-image pipe for it.
I had some trouble to get it running as I saw the following error:
DEBUG: http://host.docker.internal:2375 "GET /v1.44/images/registry-alias/my-docker-image:latest/json HTTP/1.1" 404 58
✖ Image not found error: registry-alias/my-docker-image:latest.
For me it wasn't clear what I did wrong as I was using the example from the docs:
"Building and pushing the ecr-public image with default options"
script:
  # build the image
  - docker build -t my-docker-image .
  # use the pipe to push the image to AWS ECR
  - pipe: atlassian/aws-ecr-push-image:2.4.0
    variables:
      AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID
      AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY
      IMAGE_NAME: my-docker-image
      ECR_PUBLIC: "true"
      PUBLIC_REGISTRY_ALIAS: registry-alias
Finally I've got it running after reading the source code of the pipe which makes it mandatory to tag the image as follows (PUBLIC_REGISTRY_ALIAS as prefix):
script:
# build the image
- docker build -t registry-alias/my-docker-image .
Would be cool if you could change the example or leave a note somewhere in the README to avoid confusion for other people.
Cheers, Nino
Igor Stoyanov
July 26, 2024
@Nino Gresenz hi. We updated an example you suggested in the pipe README.
Regards, Igor
Ben
July 16, 2024
Hi @Nino Gresenz
I believe the documentation example may be intentional because PUBLIC_REGISTRY_ALIAS is only mandatory if ECR_PUBLIC is set to true.
Regardless, I've shared this feedback with our pipes team - thank you for your input :)
Cheers!
- Ben (Bitbucket Cloud Support)
