Pipeline Deployment to Lambda
Jack Brooks
April 21, 2020
I'm unable to use AWS CodeDeploy for Lambda via Bitbucket Pipelines. It's saying that the bundle needs to be YAML or JSON, but the documentation and examples indicate that I need to create a zip file. Can anyone give me some guidance here? Details follow.
Version of pipe: atlassian/aws-code-deploy:0.5.2
Steps to reproduce: Pushing changes to master branch, triggering a pipeline job.
I created my pipeline file using this documentation.
bitbucket-pipelines.yml:
pipelines:
default:
- step:
name: Build and package
script:
- apt-get update && apt-get install -y zip
- zip myapp.zip lambda_function.py appspec.yaml
artifacts:
- myapp.zip
- step:
name: Upload lambda zip
script:
- pipe: atlassian/aws-code-deploy:0.5.2
variables:
AWS_DEFAULT_REGION: $AWS_DEFAULT_REGION
AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID
AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY
COMMAND: 'upload'
APPLICATION_NAME: $APPLICATION_NAME
ZIP_FILE: 'myapp.zip'
Relevant Build Log:
aws s3 cp myapp.zip s3://<bucket>/<key>
INFO: Registering a revision for the artifact.aws deploy register-application-revision --application-name <app-name> --revision revisionType=S3,s3Location={bucket=<bucket>,key=<key>,bundleType=zip}
An error occurred (InvalidRevisionException) when calling the RegisterApplicationRevision operation: BundleType must be either YAML or JSON
Oleksandr Kyrdan
May 28, 2020
Hi @Jack Brooks ,
Thank you for your question!
We are working on aws-code-deploy pipe adding support AWS ECS and Lambda deploy, not only EC2.
Could you please share more details with us, why did you decide to use aws-code-deploy to deploy lambda instead of aws-lambda-deploy or aws-sam-deploy?
One of the solutions, in your case, might be:
image: atlassian/default-image:2
pipelines:
default:
- step:
script:
artifacts:
- myapp.zip
- step:
script:
# Update lambda code and publish a new version
- pipe: atlassian/aws-lambda-deploy:0.5.3
variables:
FUNCTION_NAME: $FUNCTION_NAME
COMMAND: 'update'
# Read results from the update pipe into environment variables
-BITBUCKET_PIPE_SHARED_STORAGE_DIR="/opt/atlassian/pipelines/agent/build/.bitbucket/pipelines/generated/pipeline/pipes"
- VERSION=$(jq --raw-output '.Version' $BITBUCKET_PIPE_SHARED_STORAGE_DIR/aws-lambda-deploy-env)
# Point an alias to the new lambda version
variables:
COMMAND: 'alias'
ALIAS: 'production'
VERSION: '${VERSION}'
