×Getting this issue in Piplelines. Is there a service disruption?
rpc error: code = Unknown desc = failed to pull and unpack image "docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-auth-proxy:prod-stable": failed to resolve reference "docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-auth-proxy:prod-stable": pulling from host docker-public.packages.atlassian.com failed with status code [manifests prod-stable]: 503 Service Unavailable
Hi @Tim Kist,
The engineering team is currently looking into this issue, you can subscribe for updates on the following incident report on our status page:
https://bitbucket.status.atlassian.com/incidents/p34t0g9dmk2w
Theodora
Hi! Getting the same issue as well with 500 Internal Server Error:
rpc error: code = Unknown desc = failed to pull and unpack image "docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-auth-proxy:prod-stable": failed to resolve reference "docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-auth-proxy:prod-stable": pulling from host docker-public.packages.atlassian.com failed with status code [manifests prod-stable]: 500 Internal Server Error
Same here.
Same issue
rpc error: code = Unknown desc = failed to pull and unpack image "docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-docker-daemon:v20.10.24-multiarch-prod-stable": failed to resolve reference "docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-docker-daemon:v20.10.24-multiarch-prod-stable": pulling from host docker-public.packages.atlassian.com failed with status code [manifests v20.10.24-multiarch-prod-stable]: 500 Internal
Hi everyone,
I believe you were affected by the following incidents which have now been resolved:
https://bitbucket.status.atlassian.com/incidents/vhr4kf5rqz71
https://bitbucket.status.atlassian.com/incidents/19b4rq4rwfqw
At the top of both pages, there is a link Subscribe to updates, if you would like to get notifications when we create, update, and resolve an incident.
Theodora
I tried to upgrade docker image from node: 16.14.0-slim to 16.14.0
and this is happening.
Same issue happening right now
Hi @Bjorn Basar, @Adriaan Swanepoel and @김경민,
I believe you were affected by the incidents we had earlier today:
The incidents have been resolved now, our apologies for the inconvenience this may have caused to you and your team.
At the top of the status page, there is a link Subscribe to updates. You can use that if you would like to get subscribed and get notifications when we create, update, and resolve an incident.
Theodora
Same issue here right now:
same problem happening RN
rpc error: code = Unknown desc = failed to pull and unpack image "docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-docker-daemon:v20.10.24-multiarch-prod-stable": failed to resolve reference "docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-docker-daemon:v20.10.24-multiarch-prod-stable": pulling from host docker-public.packages.atlassian.com failed with status code [manifests v20.10.24-multiarch-prod-stable]: 421 Unknown
Im having the same problem today as well.
having the same problem as well
Same problem here in my pipelines
@dionizioaf I was experiencing the same issue, but now is working properly.
Just tried again and its working now.
Hi! Getting the same issue as well with 500 Internal Server Error.
EDIT: Sorry, this was meant to be a reply to the comment above.
