I pushed some commits to Bitbucket repositories and received emails stating that the pipelines have failed.
The pipeline logs indicate that the errors were caused by connection issues to archive.ubuntu.com during the apt-get update
and apt-get install
steps of the pipeline.
Re-running the pipelines a few times resulted in them eventually succeeding, however, this took much longer than normal. Some of the build times were over 5 minutes, when normally they rarely reach 2 minutes
The errors, retries, and extended build times due to network issues resulted in me receiving an alert about reaching the monthly minute quota in the first week of the month.
I've never reached the monthly quota before due to the typically short build times. Whenever I had encountered a pipeline failure previously, I just re-ran the pipeline (changing something on my server beforehand if necessary) and it ended up working fine. In this situation, however, it led me to reaching the monthly quota.
As the excess build time appears to have been caused by network issues in Bitbucket's systems (specifically their connection to archive.ubuntu.com), could you please reimburse the excess build minutes or reset our quota?
This looks like a network issue with Bitbucket’s connection to archive.ubuntu.com, which explains the slow installs and retries eating up your quota. To prevent it happening again, you could try caching dependencies, using a regional mirror, or creating a custom Docker image with packages pre-installed.
Since this case seems tied to Bitbucket’s infrastructure, I’d recommend opening a support ticket
so they can review your logs and possibly reset the minutes.
We're on the free plan, so I don't think we're able to open a support ticket.
The support page states "Bitbucket Free comes with Community Support. Upgrade to a paid plan to get one-on-one customer support" and has a link to this forum.
I've opened a ticket on your behalf with our support team. Please check the email that you've used to raise this ticket for further correspondence.
Cheers!
- Ben (Bitbucket Cloud Support)
