Pipeline - running integration tests with mqtt
Stian Fagereng
July 18, 2022
Hi
I want to set up my pipeline to run integration tests, and in our solution we are using mysql and mqtt.
I would love to include those when running my tests.
I setup a myqsel service in my pipeline.yml file and it works fine, but when it comes to setting up a mqtt-server I find it more difficult.
What is your recommended way of setting up a mqtt server in the pipeline, using a service in the pipeline.yml file (In that case could you show me a sample of a configuration setup)  or an external docking image that is used from the pipeline?
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
