Pipeline runs when remote branch is created
Jani Ruohomaa March 31, 2020 edited
We have this setting in yaml:
This is run when I create the branch to remote (we create them from jira tickets)
How can we do so that it is run when new commits are pushed to the feature branch not when it is created in remote.
Jani
branches:
feature/*:
- step:
name: Run when commits pushed to feature branch
trigger: automatic
services:
- docker
script:
mkleint
April 1, 2020
I believe this setup is currently not supported.
I can't even think of a viable workaround apart from only pushing with commits. Maybe you could have a script inside a build that skips remaining steps when the diff to master branch is empty? That way it will trigger but not really spend heaps of build minutes?
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
