Pipeline tests results
Jérôme Godbout
The unit test gathering seems rather very limited. We only get the first 100 errors and nothing for the successful tests or any times.
Is there any plugins or any way to get more informations then that or to track the progression or even better regression in the number of tests?
Side note: can we have a variable to specify the tests results please, having predefined folders is not suitable for ll use cases. Support for .json test results would be great too, make smaller test results file.
Jérôme Godbout
Maybe I'm missing something but could not found anything into the atlassian marketplace:
https://marketplace.atlassian.com/search?hosting=cloud&product=bitbucket&query=jest
If we are talking about generating more artifact that I have to open to consult on each build and not seeing any thread, I guest we should send the test result on jenkins on build hook to make some graph and follow the tests results, having only the failed tests is bad, if a test was not run or stop existing nobody will ever notice.
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
