Pipeline trigger based on branch
Eric Muelbredt June 23, 2025
it is not quite clear to me what the structure of the yml file is for different branches.
I need the possibility to run different validation jobs per branch.
If I create a PullRequest against stage, the validation job of develop still runs.
image: node:18
pipelines:
pull-requests:
'**->develop':
- step:
name: "Validate for PR to develop"
caches:
- node
script:
- echo "Installing Salesforce CLI..."
- npm install --global @Salesforce/cli
- echo "Installing sfdx git delta plugin..."
- echo y | sf plugins:install sfdx-git-delta
- sf plugins
- echo "Authenticating with Salesforce using authURL for develop (PR)..."
- echo "$SF_AUTH_URL_DEV" > authfile.txt
- sfdx auth:sfdxurl:store --sfdx-url-file authfile.txt --setalias devOrg --setdefaultusername
- echo "Creating delta packages for new, modified or deleted metadata..."
- mkdir -p changed-sources
- sf sgd:source:delta --to "HEAD" --from "origin/develop" --output changed-sources/ --generate-delta --source force-app/ -i .forceignore
- chmod +x ./deployment/script/*.sh
- echo "Running validation script for develop..."
- ./deployment/script/validate.sh devOrg
'**->stage':
- step:
name: "Validate for PR to stage"
caches:
- node
script:
- sf plugins
- echo "Authenticating with Salesforce using authURL for stage (PR)..."
- echo "$SF_AUTH_URL_STAGE" > authfile.txt
- sfdx auth:sfdxurl:store --sfdx-url-file authfile.txt --setalias stageOrg --setdefaultusername
- sf sgd:source:delta --to "HEAD" --from "origin/stage" --output changed-sources/ --generate-delta --source force-app/ -i .forceignore
- echo "Running validation script for stage..."
- ./deployment/script/validate.sh stageOrg
Brita Moorus
Hi! 👋
Bitbucket Pipelines doesn’t recognize '**->branch' syntax for pull-request triggers. Instead, the correct way to specify a PR trigger for a branch is just the branch name, like this:
pull-requests:
develop:
- step:
stage:
- step:
You can also check Atlassian's documentation on Pipeline start conditions: https://support.atlassian.com/bitbucket-cloud/docs/pipeline-start-conditions/
Let me know if this helps! ✨
Eric Muelbredt June 24, 2025
If I adopt your syntax and create a pull request against develop, nothing happens. So no job is executed.
Saxea _Flowie_
June 24, 2025
Hi @Eric Muelbredt
The syntax matches against the source branch, not the target branch.
You might want to have a look at Flowie, a Bitbucket app we provide, which gives you more control over the pipelines trigger. It supports trigger based on target branch like you are trying to achieve, for instance.
Found a solution.
image: node:18
pipelines:
pull-requests:
'**': # Wildcard triggers for all PRs
- step:
name: "Validate PR for develop, stage or main"
caches:
- node
script:
echo "Source Branch: $BITBUCKET_PR_SOURCE_BRANCH"
echo "Target Branch: $BITBUCKET_PR_DESTINATION_BRANCH"
npm install --global @salesforce/cli
sf plugins
# Branch-based environment detection
if [ "$BITBUCKET_PR_DESTINATION_BRANCH" = "develop" ]; then
ORG_ALIAS="devOrg"
FROM_BRANCH="origin/develop"
elif [ "$BITBUCKET_PR_DESTINATION_BRANCH" = "stage" ]; then
ORG_ALIAS="stageOrg"
FROM_BRANCH="origin/stage"
elif [ "$BITBUCKET_PR_DESTINATION_BRANCH" = "main" ]; then
echo "Authenticating with Salesforce using authURL for production (PR)..."
echo "$SF_AUTH_URL_PROD" > authfile.txt
sfdx auth:sfdxurl:store --sfdx-url-file authfile.txt --setalias prodOrg --setdefaultusername
ORG_ALIAS="prodOrg"
FROM_BRANCH="origin/main"
else
echo "❌ Unsupported PR target branch: $BITBUCKET_PR_DESTINATION_BRANCH. Aborting."
exit 1
fi
sf sgd:source:delta --to "HEAD" --from "$FROM_BRANCH" --output changed-sources/ --generate-delta --source force-app/ -i .forceignore
echo "Running validation script..."
./deployment/script/validate.sh "$ORG_ALIAS"
Like Brita Moorus likes this
Brita Moorus
Glad to hear you found a solution! 😊
