Pipeline with deployments and several manual steps.
aiviso November 16, 2023
Hi everyone,
I have been struggling for a while to understand how to write a pipeline for this seemingly simple scenario:
We have two environments (deployments): staging and production.
Each of them have 3 independent steps to run, all of them to be triggered manually and independently (because we may need to time them based on daily traffic patterns  and/or sometimes we don't want to run all steps in that deployment).
So it looks like something like this:
Test, build  & etc       ->        Staging             ->       Production
                                                    | -> Step1 (manual)       | -> Step1 (manual)
                                                    | -> Step2 (manual)       | -> Step2 (manual)
                                                    | -> Step3 (manual)       | -> Step3 (manual)
I have tried with stages, but that seems to be not possible because you cannot have manual steps within the stage.
I also tried to use parallel to be able to run each manual step independently each from other, but then I cannot use "deployment" tag because they are not allowed to be repeated.
Not sure what I am missing. I am coming from GL where this was fairly easy to be set.
Thanks in advance.
Theodora Boudale
November 17, 2023
Hi @aiviso,
If you want all six steps to be triggered manually and independently from each other, you can create a custom pipeline for each of these steps:
You can then execute only the custom pipelines that you want.
If a step in a pipeline is manual, then all the previous steps of this pipeline need to complete successfully, in order to trigger this specific step.
We have a feature request for the ability to skip steps that you can vote for and watch: https://jira.atlassian.com/browse/BCLOUD-20833
And another one for manual steps in a stage: https://jira.atlassian.com/browse/BCLOUD-22223
In the meantime, custom pipelines would allow you to trigger only the steps you want.
Please feel free to reach out if you have any questions.
Theodora
aiviso November 17, 2023 edited
Hi @Theodora Boudale , thanks for the answer. The question, though is still how to use environments in these steps? As far as I can see I can only define each environment once in the pipeline, correct? So if I have 3 steps for staging and 3 steps for production, that will not gonna work?
Besides that, I want to trigger the pipeline and execute 'test & build' stage on branch.
Something like this:
pipelines:
branches:
master:
- step:
script:
- echo "Test & Build"
- parallel:
steps:
- step:
deployment: staging
trigger: manual
script:
- echo "Staging 1"
- step:
deployment: staging
trigger: manual
script:
- echo "Staging 2"
- parallel:
steps:
- step:
deployment: production
trigger: manual
script:
- echo "Production 1"
- step:
trigger: manual
script:
- echo "Production 2"
but that is not possible because of repeated deployment clause with the same value. But again, I cannot move deployment clause to parallel because parallel does not support it.
Not sure how to solve it. Seems to be fairly simple use case :(
Like Sabine Mayer likes this
Theodora Boudale
November 20, 2023
Hi @aiviso,
I'm afraid that this is not possible with a single pipeline. Stages are the way to have multiple steps with the same deployment environment in a single pipeline, however, you can't have a manual trigger in a stage's step or skip a step in a pipeline to run the steps independently. This is why I recommended a custom pipeline for each of these steps:
An example yaml file would be the following:
pipelines:
branches:
master:
- step:
script:
custom:
staging-1:
- step:
deployment: staging
script:
- echo "Staging 1"
staging-2:
- step:
deployment: staging
script:
- echo "Staging 2"
staging-3:
- step:
deployment: staging
script:
- echo "Staging 3"
production-1:
- step:
script:
production-2:
- step:
script:
production-3:
- step:
script:
- echo "Production 3"
This way the branches: master pipeline will run automatically when there are new commits on master branch.
You can then trigger any of the custom pipelines you want independently.
You can trigger a custom pipeline in one of the following ways:
  • On the Pipelines page of the repo, there is a Run pipeline option at the top (next to Schedules). You can select a branch and then the custom pipeline you want to run.
  • While viewing the Branches page of the repo, you can select the 3 dots under the Actions column for a branch > Run pipeline for a branch.
    This option and the previous one will run the custom pipeline for the latest commit of the branch. If you want to run the custom pipeline for a previous commit of master and not the latest one. see the next option.
  • You can trigger it for a specific commit if you open the commit on Bitbucket website and select Run pipeline from the right sidebar (at the bottom)
Theodora
