Pipelines - aws: command not found
Augusto Cordero February 27, 2019 edited
I'm trying to install AWS CLI using pipelines with the following commands :
# Installe and init AWS CLI
- apt-get update && apt-get install -y python-dev
- curl -O https://bootstrap.pypa.io/get-pip.py
- python get-pip.py
- pip install --upgrade --user awscli
Then when I run :
aws --version
Throws this error
bash: aws: command not found
Any help?
Edwin Kyalangalilwa
February 28, 2019
Hi @Augusto Cordero ,
Install awscli from apt
- apt-get update && apt-get install -y awscli
- aws --version
Augusto Cordero February 28, 2019
Thanks, it works for me.
It seems that the version installed with this command is not the latest version and cannot handle the aws commands : ecr and ecs, which are what I need.
Edwin Kyalangalilwa
February 28, 2019
I would then recommend using Python 3
- apt-get update && apt-get install -y python3-pip
- pip3 install -U awscli
- aws --version
Ok, with this version the commands are working properly. Thanks.
AJ Steers May 15, 2019
Edwin - Do you have another base image for builds you can recommend that already contains the aws CLI?
Edwin Kyalangalilwa
May 16, 2019
Hi @AJ Steers ,
If all your doing is running awscli commands in the image, then i would recommend a lightweight alpine image .. governmentpaas/awscli - which is based on governmentpaas/curl-ssl
More options - awscli docker hub
Like • AJ Steers likes this
AJ Steers May 16, 2019 edited
Thanks very much! I'm also looking for python3.5+ so I might just have to roll my own image to get both. I did a quick search on dockerhub but nothing popped up.
AJ Steers May 30, 2019
I did end up building my own image `aaronsteers/builder:python3.7-aws`. I've setup automated build and made the image public on dockerhub.com:
Like • ktomk likes this
Crafton March 26, 2020
Atlassian also has an alpine image for the awscli: https://hub.docker.com/r/atlassian/pipelines-awscli
Like • Edwin Kyalangalilwa likes this
Vadzim Kapichenka
September 29, 2019
Aruna
August 17, 2022
Thank you... after 16hrs i found this
