×I'm trying to configure Bitbucket pipelines to test my angular web app.
I've already dockerized my app and configured all necessary environment, so my app runs in docker container successfully.
My problem is that all my protractor tests fail in Bitbucket pipelines by timeout (Angular is not found on the page).
But when i start my docker container on my local machine, the tests work properly.
I want to to make my tests work with the pipelines.
Actually i followed the manual described here: https://confluence.atlassian.com/bitbucket/bitbucket-pipelines-792496469.html.
But i also had to create docker image for my app and configure there required environment.
If you want to ask something exact, you are welcome. I'll share my experience.
Can you please guide me on how to run my protractor tests on the pipeline? My yml is this
Same issue with me:
1. What are the needed source files to run protractor in bitbucket pipeline since it is serverless?
2. And what is the correct configuration in the .yml file?
I manage to make it work!
Can you share, how you integrated protractor with Bitbucket pipeline?
