I have a server with many different projects running on it, and am wondering if there's a way to configure an SSH user at the workspace level to run deployments.
It's a pain to generate a new key for each repo and add to authorized_keys for my deployment user, and if I ever needed to invalidate those keys, I would need to go through every repo and generate a new one.
I'm just hoping there's an easier way to do this. The other alternative I thought of was to save a key as a workspace environment variable, and then pass it to the various pipelines that way, but it seems there are security issues with this method, so I was hoping to avoid it.
Thanks in advance!
Hello, @bobby jenrow
G'day.
Is your repositories under the same Workspace "bitbucket.org/<WorkspaceId>"?
If yes, I believe you can add the SSH key on your Workspace level, allowing the SSH key to be used with all repositories under your Workspace.
You can find these settings under the Workspace settings > SSH key or access it at the following URL by changing the Workspace ID with yours:
https://bitbucket.org/<WorkspaceID>/workspace/settings/ssh-keys
Syahrul
Hey @bobby jenrow
This is for Bitbucket cloud and not the server.
May I know your expected workflow here so I can better advise you? Details such as cloning the repository and deploying to another repository etc?
Syahrul
I want to deploy any number of repositories to a single server that I control.
In order to do that with pipelines, I set up an SSH key in each repository, register the ip address / fingerprint, and use it within my Bitbucket pipelines file. Then I need to go to my server and add the public key to my deployment user's ~/.ssh/authorized_keys
It would be nice to be able to set the SSH key up as a workspace variable that can be used from any bitbucket pipeline yml within the workspace. This way, when we migrate servers, we don't have to go back into each repo individually and update the project with a new key.
Thanks @bobby jenrow
You can use workspace variables to add the utilise that can be utilised with all pipeline builds within your workspace. You can find them at
https://bitbucket.org/<WorkspaceName>/workspace/settings/pipelines/account-variables
However, it's important to note that currently, there is no single SSH key for workspace-level usage that can be employed across multiple pipelines. The SSH key provided under workspace settings is primarily intended for pushing changes to Bitbucket and is not meant for deployment purposes.
Therefore, I recommend utilizing the workspace variables for your current needs.
Syahrul
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
