Problem running script via ssh in Pipelines
Patricio Gayol
March 15, 2019 edited
Hi everyone!
A few days ago, my pipeline (which was working right until then) stopped working. My files are the following:
bitbucket-pipelines.yml
image: atlassian/default-image:2
pipelines:
branches:
develop:
- step:
name: Deploy develop to DigitalOcean.
caches:
- node
deployment: test
script:
  - cat deploy-develop.sh | ssh (Droplet URI)
 devploy-develop.sh
#!/usr/bin/env bash
cd projectFolder
git pull
docker stop projectContainer
docker rm projectContainer
docker tag
docker build --build-arg enviroment=develop -t project .
docker run -d -p 4200:4200 --restart on-failure --name projectContainer project .
docker rmi $(docker images --filter "dangling=true" -q --no-trunc)
As I said, it was working perfect for months, but in the last days, every time I run the pipeline, I get the following console output:
+ cat deploy-develop.sh | ssh (DROPLET URI)
Pseudo-terminal will not be allocated because stdin is not a terminal.
Warning: Permanently added the RSA host key for IP address ('IPADDRESS') to the list of known hosts.
Welcome to Ubuntu 16.04.3 LTS (GNU/Linux 4.4.0-142-generic x86_64)
* Documentation: https://help.ubuntu.com * Management: https://landscape.canonical.com * Support: https://ubuntu.com/advantage Get cloud support with Ubuntu Advantage Cloud Guest: http://www.ubuntu.com/business/services/cloud121 packages can be updated.0 updates are security updates.New release '18.04.2 LTS' available.Run 'do-release-upgrade' to upgrade to it.
.-bash: line 3: cd: projectFolder: No such file or directory
git: 'pull' is not a git command. See 'git --help'.Did you mean this? pull
Error response from daemon: No such container: projectContainer
(goes on)
Apparently, simple command as "cd" or "git pull" are not working well now.
If I ssh into my droplet and run the script, it works right. The problem appears when the pipelines tries to run it.
Any ideas?
Thank you!
mkleint
October 21, 2019
that `cd` command failed not because cd is not present on the image, but because `projectFolder` is not a subdirectory of current working directory.
git should be installed on atlassian/default-image:2 as per https://hub.docker.com/r/atlassian/default-image/
not sure how `docker stop projectContainer` ever worked given that the container is likely not running or present at the start of the step. Unless you have some additional script entries before the listed shell script.
