Problem to authenticate in bitbucket-clear-cache pipeline
Karina Melo Rodrigues October 31, 2022
Recently, I've tried to use bitbucket-clear-cache pipeline in a project following the documentation. I used the pipeline credentials, but I'm getting this error of the image that Bitbucket no longer supports account passwords for API authentication.
Is that a way to authenticate to use this pipeline to clear the cache? Or exists another solution to do this?
Thanks in advance.
Syahrul
November 1, 2022
Hey @Karina Melo Rodrigues
Welcome to the community.
It would be best if you used App Passwords as your credentials since we no longer support using Atlassian account credentials.
This is why you received the following error message the credentials you use to authenticate are not an App Password.
Let me know how it goes.
Syahrul
Karina Melo Rodrigues November 3, 2022
Hi @Syahrul
Thank for answering! I already tried to use app passwords for both user and password and just only for the password, but I get an error that they are null on running the pipeline.
This project was updated for the last time in 2021-02-02, is there another solution to clean the caches?
Syahrul
November 3, 2022
G'day.
The screenshot error means you are not supplying value to App Password and Username; hence it returns a "null value are not allowed" error.
Please ensure you've added the variables in the repository settings for $BITBUCKET_USERNAME and $BITBUCKET_APP_PASSWORD with your Username and App Password.
Syahrul
Karina Melo Rodrigues November 7, 2022
Hey, @Syahrul
Thanks for answering! My mistake was I didn't understand that the variables of my account settings has to be the same in the repository. With your explanation, I did run the pipeline successfully.
Thank you very much!
Like Syahrul likes this
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
