Problem to deploy Azure Static Web App
Blagovest Doshkov
December 5, 2023
We are using BitBucket pipelines and we haven't got an issue until now.
We are using the pipeline to deploy Azure Static Web App.
The pipeline was working correctly until now. It executes "successfully" but deployment is not conducted.
Our pipeline looks like this:
image: atlassian/default-image:3
image: node:20.10.0
pipelines:
custom:
Build and deploy:
- step:
name: Build and Deploy to Dev
caches:
- node
deployment: Dev
script:
- cd App.Destination
- npm install @angular/cli -g
- npm install
#production configuration actually holds the variable names of the Bibucket deployment variables
- ng build --configuration=production
#- uname -mrs
- pipe: microsoft/azure-static-web-apps-deploy:main
variables:
VERBOSE: 'true'
APP_LOCATION: '$BITBUCKET_CLONE_DIR/App.Destination/dist/app'
SKIP_APP_BUILD: "true"
 We saw that the pipe "microsoft/azure-static-web-apps-deploy:main" is not initiating a deployment any longer.  The output of this pipe can be seen in the attached screenshots.
The last two line of the output of this pipe are the following:
Digest: sha256:c5c8b14fb91853c4903ea62c5f25d57b5913e6c09efaa24e2aa1c9324101f748
Status: Downloaded newer image for staticwebapps.azurecr.io/bitbucket-deploy:stable
Is there any alternative to configure the BitBucket pipeline to deploy the Azure Static Web App other than the usage of "microsoft/azure-static-web-apps-deploy:main" pipe.
Thanks in advance.
4 votes
Blagovest Doshkov
December 6, 2023
For those who are still trying to find a workaround:
Instead using the mentioned pipe "microsoft/azure-static-web-apps-deploy:main" we are installing the swa cli and calling the "deploy" command.
This has been tested for Angular app without an API.
- npm install -g @azure/static-web-apps-cli
- swa --verbose=silly deploy "$BITBUCKET_CLONE_DIR/<app-folder>" --deployment-token=$deployment_token --en
3 votes
Yee Jian Tan
December 5, 2023
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
