I want to run custom pipes or image with self hosted runner for deploy to on-prem.
Is this not supported?
If not, how should I use it?
Hello @dahoon jeong ,
As pipes rely on docker containers to work, it's only possible to run pipes when using Linux Docker self-hosted runners. Other types of runners that run directly in a shell session, such as macOS Runners , Windows Runners and Linux Shell runners, do not currently support using pipes.
Having said that, if you are already using Linux Docker self-hosted runners, you should be able to run pipes as usual, using the same syntax you would use if your build was running in the cloud. Please find below an example YML definition :
pipelines:
default:
- step:
name: Using a pipe with Linux Docker runner
runs-on:
- 'self.hosted'
- 'linux'
script:
- echo "This is an example step"
- pipe: atlassian/email-notify:0.8.0
variables:
USERNAME: 'myemail@example.com'
PASSWORD: $PASSWORD
TO: 'example1@example.com, example2@example.com, example3@example.com'
HOST: 'smtp.gmail.com'
Hope that helps! Let me know in case you have any questions.
Thank you, @dahoon jeong !
Patrik S
