Problems with using pipes in a self hosted runner with deploying to beanstalk
David Bergevoet February 21, 2022 edited
I try to run the following pipeline:
This will cause the errors on bitbucket pipelines (docker: sed: write error). I dont know where this error comes from. It will work when i run this configuration on the bitbucket servers, by removing the runs-on keyword and variables. This will also deploy the right version to beanstalk.
Where does this error come from and how can i fix this?
image: mcr.microsoft.com/dotnet/sdk:5.0
pipelines:
pull-requests:
- step: test_pipeline
runs-on:
- 'self.hosted'
- 'linux'
- 'build'
script:
- pipe: atlassian/aws/elasticbeanstalk-deploy:1.0.2
variables:
AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID_DEV
AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY_DEV
AWS_DEFAULT_REGION: '<environment>'
APPLICATION_NAME: '<name>'
ENVIRONMENT_NAME: '<environment>'
ZIP_FILE: '<some zip>'
S3_BUCKET: 's3bucket>'
WAIT: 'true'
[Edit] Other pipelines which dont need a pipe will run successful without problems
Norbert Csupka
February 23, 2022
Hi David,
Thank you for contacting Atlassian Support, my name is Norbert and I'm a Bitbucket Cloud Support Engineer, it's nice to meet with you! Welcome to the Atlassian Community!
  • Can you let me know whether the configuration that you posted, is that your full bitbucket-pipelines.yml file?
  • Also, would it be possible for you to give us the runners logs from that timeperiod, when the build fails?
You can check the logs, by doing the following command on the host machine:
docker logs -f runner-runnerUUID
 Please let us know, we're here to help.
Best Regards,
Norbert
Atlassian Bitbucket Cloud Support
David Bergevoet February 23, 2022
Hi @Norbert Csupka
Thank you for reacting! Here you have the entire bitbucket-pipelines.yml and the docker log of a single execution.
pipelines:
pull-requests:
- step:
runs-on:
- 'self.hosted'
- 'linux'
- 'build'
script:
- apt-get update
- apt-get install zip -y
- cd /opt/atlassian/pipelines/agent/build/Presentation/WeedIt.Web
- dotnet publish ./WeedIt.Web.csproj --output ./bin/Release/publish --configuration "Release" --framework "net5.0" --runtime linux-x64 --self-contained false
- cd ./bin/Release/publish
- mkdir YodaLogAdapter
- zip -r WeedIt.Web.zip *
- pipe: atlassian/aws-elasticbeanstalk-deploy:1.0.2
variables:
AWS_DEFAULT_REGION: 'eu-west-1'
APPLICATION_NAME: 'WeedIt Web Portal'
ENVIRONMENT_NAME: 'weeditwebportal-dev'
ZIP_FILE: 'WeedIt.Web.zip'
S3_BUCKET: 'elasticbeanstalk-eu-west-1-891169162099'
WAIT: 'true'
 docker logs:
+ ./entrypoint.sh
[2022-02-23 10:59:31,491] Runner version: 1.299
[2022-02-23 10:59:31,526] Runner runtime: linux-docker
[2022-02-23 10:59:33,849] Copying Docker cli to working directory.
[2022-02-23 10:59:34,216] Starting websocket listening to RUNNER_UPDATED events.
[2022-02-23 10:59:34,330] Updating runner status to "ONLINE" and checking for new steps assigned to the runner after 0 seconds and then every 30 seconds.
[2022-02-23 10:59:34,652] Updating runner state to "ONLINE".
[2022-02-23 10:59:36,012] Setting runner state to executing step.
[2022-02-23 10:59:36,040] Getting step StepId{accountUuid={185b1843-7b9c-4a72-b9cd-039f9a71c2fd}, repositoryUuid={73d0b75b-662c-469d-879d-f300f845acfd}, pipelineUuid={9216ad25-7a8d-4d5b-86bb-31842dcf56a2}, stepUuid={cbc7ff92-35ef-4153-ae0f-d983fd685f8b}}.
[2022-02-23 10:59:36,053] Getting oauth token for step.
[2022-02-23 10:59:36,063] Getting environment variables for step.
[2022-02-23 10:59:36,665] Getting all artifacts for step.
[2022-02-23 10:59:36,682] Getting SSH private key.
[2022-02-23 10:59:36,692] Getting known hosts.
[2022-02-23 10:59:36,936] SSH private key not found
[2022-02-23 10:59:37,008] Setting up directories.
[2022-02-23 10:59:37,018] Starting log uploader.
[2022-02-23 10:59:37,037] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_clone
[2022-02-23 10:59:37,059] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_build
[2022-02-23 10:59:37,080] Setting up step timeout: PT2H
[2022-02-23 10:59:37,082] Starting websocket listening to STEP_COMPLETED events.
[2022-02-23 10:59:37,084] Checking for step completion every PT30S seconds.
[2022-02-23 10:59:37,301] Updating step progress to PULLING_IMAGES.
[2022-02-23 10:59:37,540] Pulling image docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-dvcs-tools:prod-stable.
[2022-02-23 10:59:38,045] Pulling image mcr.microsoft.com/dotnet/sdk:5.0.
[2022-02-23 10:59:38,067] Appending log line to main log.
[2022-02-23 10:59:38,205] Pulling image docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-auth-proxy:prod-stable.
[2022-02-23 10:59:38,705] Pulling image docker-public.packages.atlassian.com/sox/atlassian/bitbucket-pipelines-docker-daemon:v20-prod-stable.
[2022-02-23 10:59:39,210] Pulling image docker-hub.packages.atlassian.com/google/pause:latest.
[2022-02-23 10:59:39,937] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_pause
[2022-02-23 10:59:39,944] Updating step progress to CLONING.
[2022-02-23 10:59:39,944] Creating container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_pause.
[2022-02-23 10:59:40,036] Starting container.
[2022-02-23 10:59:40,187] Generating clone script.
[2022-02-23 10:59:40,214] Creating container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_clone.
[2022-02-23 10:59:40,215] Executing clone script in clone container.
[2022-02-23 10:59:40,265] Starting container.
[2022-02-23 10:59:40,450] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_system_auth-proxy
[2022-02-23 10:59:40,455] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_system_docker
[2022-02-23 10:59:40,456] Creating container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_system_auth-proxy.
[2022-02-23 10:59:40,467] Creating container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_system_docker.
[2022-02-23 10:59:40,573] Starting container.
[2022-02-23 10:59:40,586] Starting container.
[2022-02-23 10:59:40,728] Adding container log: /var/lib/docker/containers/0e8aa4c11d77b48a10a847b791dfeb231b05b8cb68c819edf674640ae5310603/0e8aa4c11d77b48a10a847b791dfeb231b05b8cb68c819edf674640ae5310603-json.log
[2022-02-23 10:59:40,737] Waiting on container to exit.
[2022-02-23 10:59:40,790] Adding container log: /var/lib/docker/containers/9192aae2cc9cb2e2da993d7d6dd9d7c9ac12161eef5321ab6c13e594af88fd8e/9192aae2cc9cb2e2da993d7d6dd9d7c9ac12161eef5321ab6c13e594af88fd8e-json.log
[2022-02-23 10:59:40,796] Waiting on container to exit.
[2022-02-23 10:59:40,804] Adding container log: /var/lib/docker/containers/b8a5a2144407408f2ae65cca4e81818482915c1b96051563f15a9582cdb68455/b8a5a2144407408f2ae65cca4e81818482915c1b96051563f15a9582cdb68455-json.log
[2022-02-23 10:59:40,805] Waiting on container to exit.
[2022-02-23 10:59:40,806] Creating exec into container.
[2022-02-23 10:59:40,930] Starting exec into container and waiting for exec to exit.
[2022-02-23 10:59:41,011] Container has state (exitCode: Some(4), OOMKilled Some(false))
[2022-02-23 10:59:41,039] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_build
[2022-02-23 10:59:41,050] Appending log line to log: {34a32cc6-9cec-4c98-95f9-eceec417289b}.
[2022-02-23 10:59:41,050] Not uploading caches. (numberOfCaches: 0, resultOrError: FAILED)
[2022-02-23 10:59:41,053] Updating step progress to UPLOADING_ARTIFACTS.
[2022-02-23 10:59:41,081] Appending log line to log: {dcc487a5-c8fc-4537-819a-45b5f8ee4ec7}.
[2022-02-23 10:59:41,351] Updating step progress to PARSING_TEST_RESULTS.
[2022-02-23 10:59:41,586] Test report processing complete.
[2022-02-23 10:59:41,586] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_clone
[2022-02-23 10:59:41,815] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_clone
[2022-02-23 10:59:41,822] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_build
[2022-02-23 10:59:41,828] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_system_auth-proxy
[2022-02-23 10:59:41,993] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_system_docker
[2022-02-23 10:59:42,006] Removing container 3e598b2c-cc41-5459-95a1-746449efe490_cbc7ff92-35ef-4153-ae0f-d983fd685f8b_pause
[2022-02-23 10:59:42,058] Appending log line to main log.
[2022-02-23 10:59:42,227] Updating step progress to COMPLETING_LOGS.
[2022-02-23 10:59:42,478] Shutting down log uploader.
[2022-02-23 10:59:42,484] Tearing down directories.
[2022-02-23 10:59:42,488] Cancelling timeout
[2022-02-23 10:59:42,493] Completing step with result Result{status=FAILED, error=None}.
[2022-02-23 10:59:42,766] Setting runner state to not executing step.
[2022-02-23 10:59:42,771] Waiting for next step.
I hope this information will help and if you need more information i will supply that info.
Fabian February 25, 2022
Hi @David Bergevoet ,
is your runners host debian 11?
I had the same error and this workaround fixed it for me: https://jira.atlassian.com/browse/BCLOUD-21693
Best regards
Fabian
Like • David Bergevoet likes this
David Bergevoet February 25, 2022
Hi @Fabian
Yes the runner indeed hosts debian 11. I'll try your workaround and will check if it works for me, probably next monday.
Thank you for suggesting a workaround and have a good weekend!
Best regards,
David
Like • Fabian likes this
Norbert Csupka
February 27, 2022
Hi @Fabian
Thank you for answering David's question.
@David Bergevoet please let us know whether David's suggestion is working for you?
Best Regards,
Norbert
Fabian March 4, 2022
does the workaround fixed your issue?
Best regards,
Fabian
David Bergevoet March 6, 2022
Hi @Norbert Csupka  & @Fabian
This workaround works for me! Sorry for responding this late, but there were some things with more priority then this issue. Thank you both for responding and helping me out.
Best regards,
David
Norbert Csupka
March 7, 2022
Hi David,
Thank you for your reply, I'm glad to hear your issue is resolved.
Thanks @Fabian for your assistance on this issue.
Have a great day!
Best Regards,
Norbert
