×Hello,
The following public repository contains malicious code:
https://bitbucket.org/ethvault-tech-team/ethvault/src/master/
In file server/controllers/productController.js, the function `getCookie` downloads arbitrary code from:
https://api.mocki.io/v2/964ug6uu
and executes it locally using `new Function(...)` with `require`.
This is a Remote Code Execution vulnerability that could fully compromise a user’s machine.
The repository has been online since July 10, 2025 and is being shared with job candidates as a “technical test”.
Please investigate and take action to remove or restrict this repository.
Please report this to abuse@atlassian.com and they will take action on it. Just note that the team will not reply back.
Thank you for raising this to our attention. I've just reported this directly to our anti-abuse team and will let you know the outcome.
Cheers!
- Ben (Bitbucket Cloud Support)
I can confirm that the content has been taken down, and the user has been de-activated
Thank you Ben and the Atlassian team for your quick action and professionalism. I really appreciate the seriousness with which this issue was handled, ensuring the safety of developers and candidates. It’s reassuring to see such responsiveness from the community and support team.
