Push to another Bitbucket repo with pipeline
Carlos Gallardo
August 15, 2023
HI, i got 2 bitbucket repos in different accounts that need to sync when pushing into a staging branch in the first one it needs to push into the second repo, created the SSH key in the first one and added in the second one
this is my pipeline
branches:
branch-stg:
     - step:
        name: Push to STG
        script:
          - git remote add staging git@bitbucket.org:target-account/target-repo.git
          - echo $'Host *.bitbucket.org\n\tStrictHostKeyChecking no' >> ~/.ssh/config
          - git push staging branch-stg -f
Patrik S
August 15, 2023
Hello @Carlos Gallardo and welcome to the Community!
It seems like you have also opened an internal ticket about the same topic and one of our support engineers is already working on that case.
With that in mind, I would suggest focusing the discussion on the internal ticket to avoid any confusion that may arise from discussing the same issue in multiple places.
Once the ticket is resolved, if you feel comfortable, you can also share the resolution here in Community, so other users can try using the same solution in case they come across a similar scenario.
Thank you, @Carlos Gallardo !
Patrik S
Carlos Gallardo
August 17, 2023
Thanks Patrik
Carmelo Francisco Gonzalez
August 28, 2023
cfg
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
