Pushing to a protected branch using OAuth
David Connack July 25, 2022
Hello.
Im trying to push to a branch that is protected using OAuth as described here.
Ive followed the documentation, but im still getting the following:
! [remote rejected] main -> main (pre-receive hook declined)
error: failed to push some refs
My script looks something like this (simplified and scrubbed)
#!/bin/bash
export access_token=$(curl -s -X POST -u "${CLIENT_ID}:${CLIENT_SECRET}" https://bitbucket.org/site/oauth2/access_token -d grant_type=client_credentials -d scopes="repository"| jq --raw-output '.access_token')
git config user.name <authorised user>
git config user.email <authorised email>
git remote set-url origin "https://x-token-auth:${access_token}@bitbucket.org/${BITBUCKET_REPO_OWNER}/${BITBUCKET_REPO_SLUG}"
echo "Now using git authenticated."
sed -i "/^\([[:space:]]*tag: \).*/s//\1$TAG/" values/envs/"$ENVIRONMENT"/"$SERVICE".yaml
git commit -a -m "[skip ci] updated image tag $ENVIRONMENT $SERVICE tag to $TAG"
git push
Everything works as expected without the branch protection rule.
Any ideas?
Thank you
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
