Reference steps using Pipelines configuration sharing and anchors
Juan Sebastian Bravo Santacruz January 15, 2025
Hi, I'm trying to export steps from a bitbucket-pipelines.yml to another repositories so I can reuse them. Here is the approach I've been trying, but hasn't been able to use the anchor tags correctly.
Source pipeline (share-template)
export: true
definitions:
  pipelines:
    share-step-build:
      - step: &build_docker_image
          name: 'Build Docker image'
          script:
            - echo "Build docker image step"
    share-step-push:
      - step: &push_into_ecr
          name: 'Push Into ECR'
          script:
            - echo "Push into ECR step"
Import pipeline
definitions:
  steps:
        import: share-template:main:share-step-build
        import: share-template:main:share-step-push
pipelines:
  branches:
   main:
     - parallel:
         steps:
           - step:
               <<: *build_docker_image
           - step:
               <<: *push_into_ecr
When I try this approach I get the following error:
No commands or pipes defined for the step at [pipelines > branches > main > 0 > parallel > steps > 0 > step]. Check that you have defined a valid "script" section.
What would it be the correct way to import these steps, so i can reuse them in my second pipeline using anchors and tags?
Theodora Boudale
January 17, 2025
Hi Juan Sebastian,
It is not possible at the moment to reuse specific steps only with shared pipelines, you can only share a whole pipeline.
In the Source pipeline (share-template) you in your post, you have some definitions for shared pipelines that look correct. Then, in the Import pipeline, you are trying to import a whole pipeline into a specific step, which is why you get this error. Shared pipelines can only be imported under another pipeline, not under a step. E.g. like the following:
pipelines:
branches:
main:
In the above example, the pipeline share-step-build is imported under the pipeline of the main branch.
We have a feature request for the ability to share individual steps:
I suggest adding your vote to that feature request (by selecting the Vote for this issue link) as the number of votes helps our product managers better understand the demand for features. You are more than welcome to leave feedback, and you can also add yourself as a watcher (by selecting the Start watching this issue link) if you'd like to be notified via email on updates.
Implementation of features is done as per our policy here and any updates will be posted in the feature request.
In the meantime, you could look into using dynamic pipelines instead for sharing a step across pipelines. This is the documentation for dynamic pipelines:
One of my colleagues has published a community article on how to share a step across pipelines with dynamic pipelines:
Theodora
Product Admin Site Admin
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
