×I've started an import from a svn repository some days ago. Now the new repository is in the list of my repos, but when I try to access it I get following error:
Repository unavailable
This repository is currently unavailable.
Besides of that I can't find a way to check the status of the running imports.
It might be that something happened and the repo needs to deleted so you are try again. If you feel its been too long go ahead and contact support at https://bitbucket.org/support(technical support link under Help)
