×Hi, I received a warning that my repo was well above the new 1GB limit, so I ran BFG Repo-Cleaner which reduced the local repo size from over 2GB to under 700MB.
However, upon a full push to the remote I see that the size has not reduced (in fact, it may have gone up).
It looks like a full gc needs to be run on the repo. Can somebody at Atlassian please run this for me?
Many thanks
Hi @tim-bbav
Often times garbage is accumulated as a result of cleanup operations - this is either removed by an automated garbage collection process (only executes once a certain threshhold is met) or via manual execution on the server-end by Atlassian staff.
I've just executed a gc which reduced the repo size from 3GB > 700MB.
Your workspace is currently consuming 989MB which is close to the 1000GB limit which will be active on 28th April. I'd suggest shrinking other repositories if possible.
Cheers!
- Ben (Bitbucket Cloud Support)
Hi, I'm worried that I'm going to lose write access on Monday unless I gc my repos again. They have definitely been reduced in size, but are currently showing much larger in my workspace. Can someone please help? (I wish there were a way of flagging gc without having to go through the forums)
Hi @tim-bbav
I've just executed gc against 2 repo's that seem to have increased in size - your workspace is below 1GB again:
434MB > 97MB
896MB > 436MB
It is very important that you and your colleagues delete your local clone for those repo's and perform a fresh clone, as this will prevent pushing back old refs and inflating the size again.
Cheers!
Hi @tim-bbav
Welcome to the community!
I notified the Atlassian support team here. They will reach out to you!
