We are starting to work with the cloud.
We get access restrictions from our internal network.
Is thee any page that describe the needed setup for firewall, ports, URLs?
Yes, complete set of ranges you'll need to look at, for all Cloud products is at https://support.atlassian.com/bitbucket-cloud/docs/what-are-the-bitbucket-cloud-ip-addresses-i-should-use-to-configure-my-corporate-firewall/
You may also want to subscribe to the blogs to be updated if they change (it's not often they do)
