Resource issues when creating an Oracle database using a pipeline
Prabha Ranaweera September 13, 2022
I want to create a Oracle Database docker image using a bitbucket pipeline. For now the pipeline runs in the default build container using a customized docker image. However the pipelines fails due to missing files. The reason for the missing files is that the Oracle installation has not happened correctly. The Oracle installation logs shows the following errors:
INFO:  [Sep 13, 2022 4:14:08 PM] Expected Value:16GB (1.6777216E7KB)
INFO:  [Sep 13, 2022 4:14:08 PM] Actual Value:0.0 bytes
INFO:  [Sep 13, 2022 4:14:08 PM] Error Message:PRVF-7573 : Sufficient swap size is not available on node "96fb79250bf1" [Required = 16GB (1.6777216E7KB) ; Found = 0.0 bytes]
INFO:  [Sep 13, 2022 4:14:08 PM] Cause: The swap size found does not meet the minimum requirement.
INFO:  [Sep 13, 2022 4:14:08 PM] Action: Increase swap size to at least meet the minimum swap space requirement.
It looks like the build container does not have enough resources to complete the Oracle installation.
 Here is the pipeline step
- step: &build_ifsapp_db
script:
- export COMMIT_VERSION=`echo ${BITBUCKET_BRANCH} | sed 's/\///g'`
- export IMAGE="ifsapp-db"
- cd $NAME_PREFIX/pipeline_scripts
- chmod +x ./build_image_ifsapp-db.sh
- HOST_UID=`id -u` TRACE=true ./build_image_ifsapp-db.sh
condition:
changesets:
includePaths:
- ifs/ifsapp-db/**
artifacts: # results of the security scan
#- ifs/ifs-db-init/target/db_init.jar
- ifs/pipeline_scripts/*.txt
services:
- docker
caches:
- docker
- trivycache
How can I increase the resources needed for this step.
Pasindu Weerasinghe
September 21, 2022
@Patrik S Now we are using a runner to run the pipeline but again we are facing a issue where one of the kernel parameters required by Oracle is not getting set.
INFO: [Sep 21, 2022 11:06:37 AM] *********************************************
INFO: [Sep 21, 2022 11:06:37 AM] OS Kernel Parameter: shmall: This is a prerequisite condition to test whether the OS kernel parameter "shmall" is properly set.
INFO: [Sep 21, 2022 11:06:37 AM] Severity:IGNORABLE
INFO: [Sep 21, 2022 11:06:37 AM] OverallStatus:VERIFICATION_FAILED
INFO: [Sep 21, 2022 11:06:37 AM] -----------------------------------------------
INFO: [Sep 21, 2022 11:06:37 AM] Verification Result for Node:514de4f75d47
INFO: [Sep 21, 2022 11:06:37 AM] Expected Value:2251799813685247
INFO: [Sep 21, 2022 11:06:37 AM] Actual Value:Current=18446744073692774000; Configured=1073741824
INFO: [Sep 21, 2022 11:06:37 AM] Error Message:PRVG-1201 : OS kernel parameter "shmall" does not have expected configured value on node "514de4f75d47" [Expected = "2251799813685247" ; Current = "18446744073692774000"; Configured = "1073741824"].
INFO: [Sep 21, 2022 11:06:37 AM] Cause: A check of the configured value for an OS kernel parameter did not find the expected value.
INFO: [Sep 21, 2022 11:06:37 AM] Action: Modify the kernel parameter configured value to meet the requirement.
On the runner itself, I have set the required kernel parameters parameter.
[root@pweelk-ifsapp-runner ~]# sysctl -a - | grep kernel.shmall
kernel.shmall = 2251799813685247
Patrik S
September 15, 2022
Hello @Prabha Ranaweera ,
From the error message you reported, it seems like the oracle program checks for the available swap memory as one of the requirements to proceed with the installation. The bitbucket cloud runners do not provide swap memory, and this is likely the reason why you are facing this error.
In this case, I would suggest you try using self-hosted runners, where you can allocate more memory to your build (up to 32GB) and might be able to access the runner's host swap memory. More details about how to configure runners are outlined in the following documentation :
Thank you, @Prabha Ranaweera .
Patrik S
Prabha Ranaweera September 15, 2022
Thank you for the response. We are trying this with a self hosted runner now and will get back to you on how that goes.
Prabha
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
