Resource not found, but it is there
Julien Masson-Ratel
September 21, 2023
When I go on to look at the source of a branch in bitbucket, let's say master, it finds the file but when I click on it, it says Resource not found. I obviously can still look at the history with git, but I like the way it is presented on bitbucket. Any idea why this might be happening?
For additional information, bitbucket cuts the display at 500 files. The first 500 work correctly and display the content, but when I search for something that would be a file after the first 500, even if filtered, it does not workScreenshot 2023-09-21 082228.png
Ben
September 24, 2023
Hi Julien,
Are you able to try to filter the results using a different browser with all add-ons disabled (or Incognito if using Chrome)? If you still encounter issues, please also clear the browser cache.
If you still do not have any luck, I will raise a support ticket on your behalf as we need you to share a HAR log (which would not be appropriate on a public forum).
Cheers!
- Ben (Bitbucket Cloud Support)
Julien Masson-Ratel
September 26, 2023
Hi, nothing has changed and it does work now. I guess it was a temporary issue. Thanks
