Hi, while we go to diff tab on pull request to start review we can see unchanged lines hidden which get expanded when shift + click is used but it needs to be done as many times as we scroll the file down till end.
So is there any short key which expand all the hidden lines at once ?
Hi Balasri,
The option to show more lines will show 10 more lines every time it is clicked. I'm afraid that there is no option to show all lines.
Apart from the workaround that Aron mentioned, there is another menu item in the same menu to View entire file. This will open the entire file in a new panel.
We have a feature request for providing the option to show all lines or making the number of lines configurable when selecting to show more lines:
You can add your vote there (by selecting the Vote for this issue link) to express your interest. You are welcome to leave feedback, and you can also add yourself as a watcher (by selecting the Start watching this issue link) if you'd like to be notified via email on updates.
Implementation of features is done as per our policy here and any updates will be posted in the feature request.
Theodora
I don't know about one.
Workaround: you have an "Open in Source" item in the "..." menu at the file. It will open the complete file on the source branch of the PR. It is not annotated with the diffs (greens and pinks), but you can see the complete file immediately.
