I see questions for this related to bamboo. But I’m using bitbucket cloud.
What is the best process for running integration tests post-deployment? Should that be in the deployment step/script? Or a build step that runs after the deployment in the pipeline? Is it even possible to run a build step after a deployment step? If so, how do I make sure I don’t run another deployment while the build(tests) are running.
I’m thinking it makes most sense to run the tests as a part of the deployment step, as then the deployment can pass/fail as a whole. Also keeps deployments in other pipelines for the same environment from running.
looking for confirmation on this approach or other ideas.
Hey Brendan,
Environment in Bitbucket is defined at a step level unfortunately, previously I have worked with Gitlab which did not have this limitation.
As per https://support.atlassian.com/bitbucket-cloud/docs/deployment-concurrency-control/ the deployments are paused if there is one running for the environment.
So it makes sense to add them in the same script and not as a separate step.
Also, generally one should run the tests before the deployment happens, is there a reason there is a post-deployment test run? If that fails would you rollback?
Or by deployment you mean just the build process?
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
